Cable rating | on ElectriciansForums
Discuss Cable rating in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Y
yarcyk
Hi All.
Just a quick question regarding cable rating.
What is the twin & earth cable rating if it is clipped directly to wall and covered in plaster.
What is installation reference method to look at for cable rating in the table 4D5 ?
Hi All.
all in bgb, if you don't know now you know you shouldn't be playing with electrics and stuff
i think what the OP is after is what reference method applies. as long as it's an uninsulated wall, it's method C.
Reply to Cable rating in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
