Hi guys!
So im doing up a chalet in France and im wanting to get a french electrician in to wire it but to save a bit of money im going to do all the chasing out. Now ive been reading through french regs and a helpful installation book but my french isnt amazing yet so was just wanting to clarify some of my findings. This is how i understand it, would you please tell me if im wrong or anything else i need to know?
1) Cant chase down more than 0.8m down the wall or 1/3 of the wall
2) Cant chase higher than 1.3m from floor
3) Vertical chases have to be 1.6m apart
4) Cant chase on the same axis, ie one from above one from below
5) Can go anywhere in the floor but has to be below all insulation, screed, boards etc
6) Can only chase a max of 1250mm horizontally between points unless it is below 1/8 of wall height then its as far as you like
7) Can chase a 30mm depth in supporting walls
8) Depending on non supporting wall construction depth can be anywhere between 16mm and 32mm ( very vague I know but didnt want to write this whole table down thats in front of me)
I assume the french electrician will use ICTA gaine throughou the installation, I cant see why he would need any thermo type so less restrictions there.
I realise this is quite vague and im sure there is alot more to it, but am I correct with these regs so far and am I missing anything important here?
I appreciate your time and advice
Many thanks
Steve
Many thanks
Steve
