Cable run under floorboards | on ElectriciansForums
Discuss Cable run under floorboards in the UK Electrical Forum area at ElectriciansForums.net
Hi Group
Had a third party inspection by a NAPIT tester, to get building control approval for a pv installation.
He has failed the cable run in Twin and Earth under my floorboards even though its greater than 50mm from surface. No 30ma RCD fitted to this circuit.
I though it was acceptable if the cable was 50mm or greater from the top of the joists?
Thanks for advice in advance
Iain
Did he give you a reg No that you are falling foul of?
Unless it's relevant to PV which I have no experience of, there's nothing wrong with running cables below floorboards.
Your biggest concern would be building regs.
Is it 50mm from the ceiling below too? ;) Edit - as Dave points out its not applicable anyway to running through floors.
Likewise I have no PV experience so leave that to the PV guys.
The inverter manufacturer SMA Sunny boy guidance says do not use an RCD with a tripping current of less than 100ma to prevent false tripping which the NAPIT tester will not accept (he wants a 30ma RCD.
The cable is fully visble for all of its run from airing cupboard and along landing.
I have not asked him yet to quote the reg he's failing it on.
Since when? There is no requirement for cables to be RCD protected purely due to be installed under a floor, regardless of whether they are 50mm deep or not!
If you think otherwise please do quote a regulation number to back this up.
Dave, could you please read my post again that you've taken my quote from.
You'll see that I'm agreeing with you that cables below the floor and above ceilings do not need rcd protection.
Post 11
Reply to Cable run under floorboards in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
