Cable run!!! | on ElectriciansForums
Discuss Cable run!!! in the UK Electrical Forum area at ElectriciansForums.net
Bolton
Mate of mine asked if there is anything wrong with some of the cable routes he found in the new property he just bought!!!
Wouldnt mind but the cables come up from DB through this bedroom into another then the attic, back into the bedroom, then down into the extension which was on the bottom floor!
Frickin crazy sparks.
[ElectriciansForums.net] Cable run!!!
Also he asked is the boiler in a good place, above the bath/shower!!!!
Plumber mate of mine is moving it into the airing cupboard about 3m away from its current position.
Reply to Cable run!!! in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
