Stoobydale
Hi, could anyone tell me if it is ok to drill through roof joists on a single storey extension to run lighting cables through? The joists are 150mm and the hole is 50mm plus in from the underside with a 13mm hole.
Discuss Cable Runs in the Australia area at ElectriciansForums.net
What options do you have if it is a vaulted roof? The only woodwork is actually rafters, would it be ok to drill in this situation?
Reply to Cable Runs in the Australia area at ElectriciansForums.net
