U
ukpablo
I cant find anywhere in the regs that state cable sheath is to be used if rcd protection is used at cu?
I always do as best practice, but if i was chasing out thin cable runs and cable clipping onto brickwork, could it not just be patched over...................would be very unlikely that a plasterer will catch cable with such a small chase?...................would be different on a bare wall.
Or plasterboard is dot and dabbed straight over the top these days too!?
Whats ur thoughts?!
:D
by cable sheath do you mean capping? if so then there is no requirement its just good practice to save from minor nicks from plasterers etc..
Not essential but good practice.:)
As far as negating the need for RCD protection it would have to be steel, and earthed, and even then not on a circuit that requires otherwise.
Ive actually tested a full rewire where the install team had used metal capping. But the customer told me that every now and again the rcbo for the skts would trip. When I did the IR test I found the leg that was causing the problem. Because the walls had already been plastered I had to rip the leg out and I found that although it had been capped the plasterer still managed to nick the cable. So although its best to use capping its not fool proof.
And I think if you do any work for the local council they do require you to use it.
Cable sheath or not?!
Australia
ukpablo,
Jay Sparks,
