Cable size and load calculations | Page 2 | on ElectriciansForums
Discuss Cable size and load calculations in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I need some help with working out the correct cable size for some work I'm doing at the moment.
I am currently working on testing Mobile units carrying out PIR and remedial works.
I have already worked out my answer which I will keep to myself as not to invite negative comments, the problem I have is that there seems to be some gray areas and I am in disagreement with a colleague at work.
I have also used many online calculator's and they give widely differing answers.
I have an existing 2.5mm thermoplastic/thermosetting 70 degree radial circuit, this is feeding an above sink 2KW water heater. The customer wishes to add a zip boiler above the sink that is rated at 2.2KW.
My question is can I just extent the exsiting circuit and by adding another 13A switched fuse spur or do I need to run another circuit?
Here are all the detail's...
Cable as stated above
Ambient air temp 30 degree
Installation method C (installed in surface mounted plastic Trunking)
Grouping derating factors. There would be a maximum of 3 other cables installed in the trunking at anytime but these vary. I suppose it would be best to use a worse case scenario.
Lighting circuit 1.5
Ring circuit 2.5
another radial 2.5
Cable run not more then 10 meters.
Could you also provide the answer as a single circuit for a type C installation.
PS: as both boilers will be constantly switching on and off at different times as the water in each will heat and cool at different times Can diversity be applied???
Thanks in advance.
yeah. table 4D5 in bgb. method B is non-existant. so it's a choice between A and C. 20A or 27A. split the diff. and call it 24A . everyone's happy, 1 radial will suffice. next job , please.
I like your reasoning but still does not answer the question in full. I think I will just continue to use the one radial and let the other guys run a new circuit. Unless I can prove my argument with sound reasoning from the regs I'm on a loser. Maybe I'll contact the IET myself.
Reply to Cable size and load calculations in the UK Electrical Forum area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
