Cable size calculating program? | on ElectriciansForums
Discuss Cable size calculating program? in the Australia area at ElectriciansForums.net
TLC Direct are on the web, they have a free one, you cant download it, but it is always there to use. they have alsorts of other calculators, for extractor fans, and god knows what else. they are also a reasonably priced wholesaler.
Cheers.......Howard
Reply to Cable size calculating program? in the Australia area at ElectriciansForums.net
The total current capacity of the system in amperes is the same as the per-phase rating when referring to a balanced three-phase system. Thus, a...
To be honest James I use an app- Electrical Calculations. It auto calculates the cable size once you enter the specifics/parameters. Voltage...
