C
chocolate
Hi.
Hoping that many of you experienced girls and guys out there will be able to help me out.
A disagreement regarding cable sizes and fuse ratings.
For example : I believe a 2.5mm2 radial ( assuming it is more than 5 metres in length ) should be rated at 16A unless there is convincing evidence that a 20A rating will not induce heating of the cable to an extent that could cause future damage.
As the lesser experienced sparks, my opinions are questioned.
More so with 4mm2 T&E. I believe a 20A rating ( again assuming a measureable run of cable ) rather than a 32A.
My query relates to cables installed as in a standard domestic environment.
Thanks for any thoughts on this matter.
