cable sizing for SC withstand | on ElectriciansForums
Discuss cable sizing for SC withstand in the The Welcome Forum area at ElectriciansForums.net
snaban
Can any one post the values of "k" for various conductor materials like aluminium and copper when used with insulations like paper,pvc,xlpe,mica,micc,enamel etc
Welcome to Electricians Forum | Electrical Advice Forum | An electrical forum for electricians in the UK!
Hello snaban, welcome aboard www.electriciansforums.net. Stick around, I'm sure you'll like the place. :)
Welcome along.:D
This is the introductions forum, try posting your question in the relevant forum. More people will see it that way.
Reply to cable sizing for SC withstand in the The Welcome Forum area at ElectriciansForums.net
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
