steve-irl
Hi all, just new here today. Just want a few opinions on cable size needed for a cable run from a main dis board to a sub dis board.
It's 3 phase 400/230V system so will be using either 5 core swa or 4 core swa with separate earth. It will be run in buried duct. The cable run is 80 metres between the boards. max load of the entire sub circuit should be about 60 amps, being generous.
Circuits off the sub board will be two 10kW 3 ph motor circuits and three single phase circuits of 4.5kW each.
Have something worked out myself but just want some more opinions as im second guessing myself as not been at this end of things for some time lol.
Thanks in advance!
Thanks in advance!
