sparkykarl
Hi Guys,
i'm currently in the process of quoting for a job I hope to win. I need to work out the size of cable required to supply 20 studio flats.
i am going to run a supply or several supplies from the basement of the building 16m up an lift shaft then will be approximately 40m through a ceiling to an isolator/s size of which is unknown at this stage. Then from the isolator/s to a three phase distribution board or more then from those boards to 20 top up electric meters then off to each studio flat with 16mm Twin and Earth.
pAny help would be helpful
Karl
Karl
