M
merlynthewizard
Hi guys, any idea on sizing this please, any help will be great, thanks in advance.
A 6kW induction motor (pf 0.95) is to be connected to a 230Volt 50Hz Supply. The motor is required to control a heist in an office furniture warehouse. The motor will be supplied by a multicore SWA cable with copper conductors. The cable will be run on a perforated tray run vertically in the warehouse. The tray also carries 3 other similarly loaded SWA cables for other various electrical loads, and the ambient temperature is 30⁰C. The distance between the main distribution board and the heist (cable run/length) is 55 metres. Calculate and answer the following:
A. The size if the cable is an “Armoured PVC Insulated Cables with Copper Conductors.
B. The size if the cable is an “Armoured XLPE Insulated Cables with Copper Conductors.
Comment on what effect, if any occurred with the cable size selected when the insulation is changed from PVC to XLPE insulation
