cable temp factor for 70/90 degrees cable | on ElectriciansForums
Discuss cable temp factor for 70/90 degrees cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bullybully45
Hi,
I'm in the process of trying to do a "monkey sheet" to enable my apprentices's to make correct cable size calculations. I'm happy about the use of the 1.2 factor used for 70 degree rated cable but I havent come across the 1.28 factor for 90 degree cable before. I would be most grateful if anyone can give me iformation on this and where I can look it up and read about it.
Cheers
Reply to cable temp factor for 70/90 degrees cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
