Cable Tray Laying | on ElectriciansForums
Discuss Cable Tray Laying in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi All,
I'm planning to install a 300mm cable tray underneath a false floor for a 95mm SWA supply cable.
The issue is the tiles underneath the false flooring that the tray needs to be fixed down to are all asbestos. I know there are specialist companies who will drill holes into asbestos tiles on your behalf but the price is excessive. I did originally consider gluing down the uni strut that the cable tray will sit on, however the supply cable will only be required for 2 years max and the tray will need to be removed again.
Has anyone encountered this issue before and if so what did you fix the tray to the floor with? Or was an alternative installation method for the cable used?
For a start ^ what he said
Why do you need a 300mm tray for 1 95mm SWA
What are the false floor supports made of just wondering how you will get a length of tray under the false floor structure
There's existing tray systems running in all directions under the floor, so its been suggested to keep it the same. However I guess it could be ran in flexible ducting if left with no other option?
The tray may eventually have other electrical circuits running with it so redundancy was required.
The false floor supports are normal pedestals (25cm) but all glued down as they are permanent.
So can you not clamp some strut between the pedestals to mount the tray on
Hi All,
Reply to Cable Tray Laying in the UK Electrical Forum area at ElectriciansForums.net
J
Traymate Shower tray Hi guys, This is my first post so apologies if this isn't the right section for the post. I'm a qualified plumbing and...
Jeefa
J
P
Large floor tile adhesive help Hi all, My 1st post and just wanting some help/reassurance on a DIY bathroom refurb. I’m putting down...
parrydave
P
