Cable tray rolling bend! | on ElectriciansForums
Discuss Cable tray rolling bend! in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Hello guys/gals,
Fabricating your own bends is normally now a dated thing in this day and age but still wise to know! I like to think I am pretty good at this but one thing I did stumble on today is doing a back to back rolling bend in cable tray?!! Making the bends is a doddle but does anyone know how to get a back to back in one length?!! Formula for it?
Thanks in advance
Doing it the other day, I just made one bend then marked and made the other. Much faster with conduit. I like installing the light gauge stuff as I own a Hilmor cable tray bender.
I do have an old engineer's bible,which describes the calculations for such work,but it is very specific,to individual types and grades of section and material.
The material has to be manufactured to very high tolerances,to remain consistent...as anyone who has done 90's in scaffold tubing,with a roller/sector bender,can testify...with every forth bend,folding :rolleyes:
It is usually easier to estimate,and gauge any alterations,on the basis of results.
With any bending done,on metal sections,it is always worth remembering,it prefers to stretch,than to compress,and compression can mean rippling.
Working with lead,dressing and forming,can give you a great,exaggerated demonstration of the properties of a metal,and assist in guessing what happens,when working less ductile materials.
Reply to Cable tray rolling bend! in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
