Cable Trench with 2 Voltage Levels (800Vac and 34.5kVac) | on ElectriciansForums
Discuss Cable Trench with 2 Voltage Levels (800Vac and 34.5kVac) in the UK Electrical Forum area at ElectriciansForums.net
Philippines
Hello,
We have a project where there are sections where 34.5kVac cables will be laid below 800Vac cables. Conductors are Aluminum.
Any chance anyone knows a standard which states the min. allowable separation distance when cables of different operating voltage levels are laid in the same trench?
Thanks in advance!
Reply to Cable Trench with 2 Voltage Levels (800Vac and 34.5kVac) in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
