Cable type for home steam room | on ElectriciansForums
Discuss Cable type for home steam room in the UK Electrical Forum area at ElectriciansForums.net
n180
Would normal twin and earth be ok for lighting in a home steam room or do I need heat resistant?
It'll be run above steam room on cold side of insulation as regs recommends, but being for lights, obviously end will be pulled through insulation.
Cable to steam generator will be standard 10mm grey cable also or am I looking at some heat resistant 10mm cable?
Thanks.
Steam room? So a sauna then? Classed as a special location. Is this commercial or domestic?
Thanks Wilko.
It's domestic.
Yes, I've already seen the regs, all wiring will be on the cold side of insulation (703.52), except the ends of the lighting wires, for obvious reasons.
I'll have to use the silicone based cable for that then I guess.
Reply to Cable type for home steam room in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
