Cable type, please... | on ElectriciansForums
Discuss Cable type, please... in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Glasgow
Is this PILC?
Found today, running along an external wall, with some all-round band for extra support...
Always interested in odd cables, so please let me know!
[ElectriciansForums.net] Cable type, please...
and a few bits of all-round "band" to help with the support!
It comes out of the ground, runs about 35 m along that exterior wall to the house, and disappears inside...the adjacent garage is fed by 4mm T&E pinned to the same wall
Many thanks for all your replies, I appreciate it.
Always trying to add to my knowledge base!
I don't think it's a water pipe, but that was a possibility at one point...however, no other water supplies run overground in this vicinity that I am aware of.
I suppose if I had to describe it, i'd say it was like a lead pipe, sheathed in what I used to know as Sylglass tape...not the metal foil covered stuff, just the basic stuff which was some kind of fabric mesh impregnated with a sticky goo...I expect some on here have never heard of it!
Whatever it is, thank you all again for your suggestions.
Could it be a water pipe?
well insulated.
stick a nail in it. if it pees out it's water. if it hisses, it's gas. if it goes bang, it's leccy.
Bog standard PILC STA. Paper insulation, lead sheath, steel tape armour and tarred hessian serving that has weathered and peeled off. You can have PILC without the armour or with SWA, but the lead always has to be there underneath to provide the hermetic seal against moisture.
Reply to Cable type, please... in the UK Electrical Forum area at ElectriciansForums.net
Twin and earth on its own isnt going to meet the requirements for burial. Why not use Swa ?
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
