Cable type question | Page 2 | on ElectriciansForums
Discuss Cable type question in the UK Electrical Forum area at ElectriciansForums.net
Scotland
I will be getting a new electric fire which operates at 1 or 2 kw's in a few days (dimplex oakhurst) to replace old gas fire. As new fire power cable is only 1.5 mtr (so I'm told) I will need just under a extra 2 mtrs of cable to reach plug socket.
Will Nexans 3183Y White 3 core Multi-core cable 2.5mm² and a 13 amp terminal connector from B&Q be suitable to join cable from fire to extra cable?
For most jobs using normal plugs and connectors simply twisting the strands together modestly is fine.
As above, do not solder wire that is used for screw terminals as it creeps with time becoming lose (if fact the wiring regs cover that somewhere).
If you do a lot of this (unlikely) or are using fine stranded wire in terminals that are intended for coarse stranded (7 strands) or single-strand then a "bootlace ferrule" is the answer. For typical 13A plugs and accessories the uninsulated sort are best, as the ones with the plastic shroud take up too much space. While you can get tools covering a huge range of prices, the self-adjusting kits from the likes of eBay/Amazon are your best bet. For example:
Mostly the are kits include the insulated ones, you can snap the colour-coded plastic bit off if you don't want to buy a pack of uninsulated ferrules.
Reply to Cable type question in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
