Cables and trunking. | Page 2 | on ElectriciansForums
Discuss Cables and trunking. in the UK Electrical Forum area at ElectriciansForums.net
tipton, england.
Hello. Could anyone tell me what would be the best size plastic trunking for 2.5mm square cable internally? my guess is probably 16mm square but not sure.
Thanks for your help.
As telectrix says, although the updated reg applies to ALL cable support systems whether or not they are in an escape route, common sense could be used to assess whether a particular length of trunking/cable/conduit would prematurely collapse in the event of a fire.
I don't like the penny washer idea. Sounds like a fine line between trying to secure the trunking to the wall but not damage the cables. The cable should not form the middle of the sandwich.
Don't scrimp on the job, get some proper D clips. Sounds like an advertising slogan that - they can buy the rights to use that if they want. Now where's that copyright symbol?
Reply to Cables and trunking. in the UK Electrical Forum area at ElectriciansForums.net
Thanks for your advice bud, I actually spoke to a Gold Card holder over the weekend of whom gave me the same advice
The suggestion from @UNG to use Unistrut inverted is good, as it is 41 x 41 outside or 41 x 21 (I think, from memory) and you can get it without...
