Cables and Zones | Page 2 | on ElectriciansForums
Discuss Cables and Zones in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hi Gents,
Probably a very simple answer but I'm installing an outside light on a small porch The switch being just inside the door.
The light however, is about 600ml from the door on the outside, so if I drill straight through from the outside to the inside, once inside, the cable exit point straight in to the back of the light outside is going to be out of the zones.
I was just wondering how people overcome this issue? I thought about drilling at an angle so that when the hole comes through to the inside, it is by the switch but I think I'll need either x-ray vision or a hell of a lot of luck, or even both, to pull this off close enough to the switch to be within a 'zone'
Any help is appreciated. Thanks.
@suffolkspark It's the dotted line? where it first exits the switch it's within the zone, but when it then has to go up the wall to then be fed outside it leaves the 'zone' provided by the switch right? Just the part where it travels up the wall.
As somebody else said above the zones go vertical and horizontal EITHER side of the wall from the accessory. It is through the wall and vertical to the light so fine in my book. And the bbb
@telectrix This is what I'm wondering, so the supply (Taken from an existing ceiling rose inside the existing dwelling) for the new porch outside light comes down from above, within the prescribed zones straight down to the switch.
However, as the light is being positioned away from the door, so in theory, about 1ft to the left of where the switch zones would be, I'm not sure if I'm allowed to run the cable outside of the zone to get in to the back of the light fixture outside?
@DPG Yeah I get that the zones run either horizontally or vertically from the switch. I'll add an image to show you guys what I mean.
@Pete999 What info did you need? Apologies. Just thought I needed to pose the question that's all!?
I have my domestic installer qualifications. I've been doing little domestic jobs for about 6 months now. I am happy with the regs/testing and go over these vigorously before any install, but some real world experiences are throwing me off a little, hence the question above. I have a seasoned electrician, who I'm helping, who comes in advises me on the installs and checks all the work I do and does the bigger parts of the jobs (CCU changes etc) for the time being, I'm just doing the "beginner" stuff like installing RFC's, lighting circuits both 1st and 2nd fix, he will then do all the work at the CCU. I literally just run the new cables etc
Again, all of which I go over with the electrician to make sure it's being done right, he is happy that I'm capable of doing these either with him, or being told what to do while he does other jobs.
It's how I'm learning the trade so far. I've completed about 5/6 installs so far all of which I've had assistance on and have been told are ok by the electrician. Is that ok?
Hi Thomas,
I'm reluctant to answer your question Mate for fear of annoying the Mods, but some information of your experience would be helpful in order to quantify my answers, it's nothing personal, nothing sinister, just some pointers on how to answer your questions
[ElectriciansForums.net] Cables and Zones
ster, nothing
@Pete999 that's cool man. I come here for help. If ya need more info then I'll happily pass it over. Cheers.
@ruston Thanks, I wasn't aware that it ran both sides of the wall. This is the stuff I'm learning on the job.
THANKS TO EVERYONE. I don't wanna miss anyone out. It's all been helpful as usual and helping me become better at this job. Only a few more years and I should be able to go solo! Cheers legends.
@anthonybragg This was my first thought tbh, but because I don't want to blow a brick out on the face of the house, I'm going to be drilling from outside inwards, and trying to get the correct angle so that I fall within the zone of the switch is going to be difficult.
It's what I'll probably have to do but I wondered if anyone had any tips or suggestions regarding the matter.
Use a thinner longe drill bit first then larger going from both sides if required.
No need Thomas you seem to have all the answers you require, it's just a quirk of mine, nice to know the experience of people you are trying to help, if you wish to keep that private, then that's your prerogative, good luck
Hello Thomas if you are still undertaking any courses then with the correct details you can have access to the Trainee section. The requirement would be that you are currently or about to start a course. If you think this applies to you follow this link.
Reply to Cables and Zones in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
