Cables and Zones | Page 3 | on ElectriciansForums
Discuss Cables and Zones in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hi Gents,
Probably a very simple answer but I'm installing an outside light on a small porch The switch being just inside the door.
The light however, is about 600ml from the door on the outside, so if I drill straight through from the outside to the inside, once inside, the cable exit point straight in to the back of the light outside is going to be out of the zones.
I was just wondering how people overcome this issue? I thought about drilling at an angle so that when the hole comes through to the inside, it is by the switch but I think I'll need either x-ray vision or a hell of a lot of luck, or even both, to pull this off close enough to the switch to be within a 'zone'
Any help is appreciated. Thanks.
No need Thomas you seem to have all the answers you require, it's just a quirk of mine, nice to know the experience of people you are trying to help, if you wish to keep that private, then that's your prerogative, good luck
I’ve also started looking at peoples profiles before answering. If they are not allowing me to see there profile I’m not responding also.
There is a lot I’m not responding too.
When house bashing new houses I used to take the view that if there was a light on the outside you could see it through the transverse no different to a socket in one bedroom backing on to another. the bit that I had trouble with was when a wall outside light is not where an exterior door is. Most cases I can move a double socket slightly or add an extra so that the outside light cable comes in inline with it.
Don’t know what kind of metal conduit you use?
The metal conduit I’ve used would.
Strange, because I've seen someone drill right through concealed steel conduit before and hit the singles contained within. I'm pretty sure Guidance Notes explicitly state that conduit wouldn't meet that requirement too and therefore needs to be earthed.
An unlucky one.
Here is the bit about mechanical protection form 522.6.204:
“(iv) be provided with mechanical protection against damage sufficient to prevent penetration of the cable by nails, screws and the like.”
Can’t see anything there about protecting against drill bits (lucky or unlucky ones).
That being said, in my experience, if you start drilling into a wall with a masonry bit, and hit conduit, the conduit either starts ringing like a bell, or the drill bit mushrooms.
Reply to Cables and Zones in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
