Cables buried in walls | on ElectriciansForums
Discuss Cables buried in walls in the Australia area at ElectriciansForums.net
sparks1234
Hertford
Now, we all know that cables in walls have to be either RCD protected, deeper than 50 mm or in steel conduit.
My question is, would metal flexible conduit count?
We install a lot of cables in petition walls for offices and installing rigid conduit is a non starter, RCD's add a lot to cost, the walls are often only 50mm thick and the other option I have just thought of (guardian cable) is also expensive
I doubt it would offer the same protection as solid steel conduit if someone hangs something with a screw or hammers in a nail.
Sorry, the point I am getting at is does it comply, no doubt steel conduit wont be penetrated, but the guardian cable complies as it is completely wrapped in a metal sheath so it shorts out, whilst I am on the subject of guardian, it should only be used with B type breakers
If the conduit is to BS61386 and satisfies the requirements for a protective conductor then yes. I doubt if the flexible stuff does though.
Reply to Cables buried in walls in the Australia area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
