Cables/corrugated metal sheeting | on ElectriciansForums
Discuss Cables/corrugated metal sheeting in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I need to bring some flex cables through so corrugated metal sheeting which is on the upper side wall of an industrial unit.
This is to supply some floodlights. I'm unsure what is the best way to go through the corrugated sheet. I dont want to use a compression gland with flex as I think that may look rough.
What are the other options? Flex con/Bush's?
Reply to Cables/corrugated metal sheeting in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
