cables inside 75mm wall and celotex | on ElectriciansForums
Discuss cables inside 75mm wall and celotex in the Australia area at ElectriciansForums.net
P
peterb2428
Hi All,
when running cables in walls of this size any recommendation for installation methods as space is tight,
currently all the cables are running in front of celotex (timber stud with not much space) but although RCD protected would you install conduit/trunking inside but this would mean cutting celotex and affecting part L?
Reply to cables inside 75mm wall and celotex in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
