Cables Selection | on ElectriciansForums
Discuss Cables Selection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
homeboyworkshop
Hi there...Help..
Recently , I'm doing some automation project's part list selection . I found worry about what type of cable is suitable for my automation machine . This machine required 3 phase 400V (around 70A application) . Problem encounter as below :
1. Is any calculation is needed to select accurately the cables size?
2. Which type(material) of cables is preferred?
Thanks...
Reply to Cables Selection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
