J
JamesBrownLive
Am I correct in thinking that the requirement for RCD protection for cables that are <= 50mm deep, does not apply to cables that simply go though a wall horizontally, from one side to another?
If so, are there limitations to exactly how horizontal the cable must be, or could you for example have a slightly downward trajectory (10 deg) and still be within the rules?
Cheers
Cheers
