Cabling in wall cavity ? | on ElectriciansForums
Discuss Cabling in wall cavity ? in the DIY Electrical Advice area at ElectriciansForums.net
Rupert
Redditch
I am having a single story extension built and was wondering if it is acceptable to have the ring main cabling in the cavity to avoid having to channel out the walls ?
Graham
why channel, when the cables can be installed pre-plastering?
Thanks for the quick responses.
We will be dot and dab plaster boarding so would normally channel out a bit to ensure that the plasterboard isn't impeded by the cabling.
Under the 17th edition what are the requirements for protecting the cable in this situation. The last electrician I had do some work for me said that we would have to either earth metal capping or fit an RCBO in the panel.
Graham
All cables concealed in wall less than 50mm from the surface should be protected by an RCD or by 3mm capping.
Dot and dab is normally thicker than the cable.
So what has your sparky said?
the cables will be well under the space behind the board. can be clipped, capped, oval tubed, but as murdoch says, unless capped with 3mm steel or in earthed metal conduit, must have RCD protection. your spark will know all this and advise you accordingly.
Graham
As you are having an electrician carry out this work, why are you not speaking to him/her?
i see a DIY (disaster in yonder) looming.
Graham
You are going to have to fit an RCBO regardless as the circuit is described by yourself as a "ring main"
I will throw my two pennoth in as well.
All general purpose socket outlets must be RCD protected.
This means either the cable supplying the socket has to be RCD protected, or the socket outlet has to be one that incorporates an RCD. BUT, there are other requirements to consider regarding the application of the regs.
So as this is in the DIY forum, please accept my word that your circuits require RCD protection, end of.
Howard
Thanks for the feedback. I am wondering what the significance is of me referring to a "ring main" making it a requirement that an RCBO be used as opposed to an RCD in a split panel that serves the circuit ?
I don't have an electrician on this job yet. I understand the difference between an RCD and an RCBO just wondered why there seems to be a preference to individual circuit RCBO's.
No sweat.
Thanks for the responses.
No sweat.
when he said fit rCBO, that's because it's a socket circuit. i assume he was thinking there may not currently be RCD protection. either will do. and just to be pedantic, it's a ring final circuit, not ring main. a ring main would be a distribution ring circuit.
Reply to Cabling in wall cavity ? in the DIY Electrical Advice area at ElectriciansForums.net
Is the property suitable for ASHP? There are quite a few unscrupulous salesmen promising all sorts, but without the insulation factors and large...
I think it's more a case of why you would hide a cable in somewhere that is intended to be a clear gap.
