calculating design current in a ring circuit | on ElectriciansForums
Discuss calculating design current in a ring circuit in the UK Electrical Forum area at ElectriciansForums.net
dave30
hello and thanks again for all your answers got another question for yous
ok im trying to calculate design current for a ring
if it was a shower unit say 7.5kw at 230 volts i would do 7500 / 230 = 32.6 amp this i no how to do
cant think how you would do it for ring or even if you can do it
could some one please help its a 32 amp ring on a 230 volt supply
Hello, the design current of the circuit is the maximum draw in the case of a ring i.e the breaker rating. If this is a cable calc there are of course many other aspects, insulation, grouping, etc. Hope that is of some help. Same for a lighting circuit or radial socket circuit etc.
Bit more complicated with a ring to determine how a load will distribute current across both legs, easiest way would be to measure continuity from your load point to the breaker on each leg, in theory the proportions of current going down each leg is inversely proportional to the resistance.
Reply to calculating design current in a ring circuit in the UK Electrical Forum area at ElectriciansForums.net
What kind of a socket? 13A, 16/32A commando, etc? Single socket on a radial, or multiple sockets off the same circuit?
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
