P
pumpkinbreath
Hi again
I also have a query about determining the installations maximum demand for when an electrical installation certificate must be filled in. I have calculated the demand for my test scenario using Appendix 1 of the On Site Guide as 103.92A using the breaker values. However I have seen post on this forum that it can be calculated by adding the sum of the breakers and then multiplying this figure by 0.4, is this a recognised method? I used it and got 43.2A, a big difference no?
I don't have the actual readings for the circuits in Amps or Watts, only breaker values as it is a practical exam.
Any suggestions...
Any suggestions...
