Calculating the current of forktruck charger | on ElectriciansForums
Discuss Calculating the current of forktruck charger in the Australia area at ElectriciansForums.net
Amp David
Mentor
Glossop
Back now,
charger has a rating of 110 amps 24 volts on the charge side of the charger, so am i right in calculating the power drawn as being
110 x 24 = 2640 W so 2640 / 230 = 11.5 A
Single phase and not 3
Reply to Calculating the current of forktruck charger in the Australia area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
