calculations | on ElectriciansForums
Discuss calculations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
snipes
hello,
this is going to be one of those qestions when i hear the answer it will come back to me, but at the moment its not!
when you mesure the end the end resistance of a ring main there is a calculation to work out the length of the circuit can someone enlighten me with this formular.
thanks in advance
table 9a of 17th edition osg give the resistance per meter 7.41 for 2.5 singles but i`m wanting to know the equation for calculating the lenth of the circuit , so the reading for instance is 1.62 ohms for L - L what is the length of the cable
Reply to calculations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
