Call out charges - whats yours? | on ElectriciansForums
Discuss Call out charges - whats yours? in the UK Electrical Forum area at ElectriciansForums.net
L
LlandrilloSpark
Afternoon fellas, I hope your all enjoying the break?
I had a call out this morning to a country house, 14 rooms all full, 75% of the building down, I was told on the phone that money was no issue to get the builing up and running as they have a jubilee dinner to prepare starting at 3pm, It turned out to be a phase down, 1 phase controlled 25% of the install, 1 phase 75% and the other the storage heaters, so i dumped the heating and put the 75% that was down on a healthy phase.
I was wondering what your call out charges are and your hourly rate there after/ Sunday, I dont do a lot of call outs.
cheers
Yes tel, L3 was down on the supply, SP energy were informed and diagnosed the problem as the link across the wooden poles had broken, I spoke to the linesman who said it could not be fixed until about 6pm so I traced the cables to find that phase L2 powered the storage heaters only so I swapped the load tails around in the Henleys and got it up and running, I had to sacrifice their heating but they would rather that than have 30 very unhappy guests at ÂŁ175 a night!
Yep I don't want to rip them, It will work out at approx ÂŁ 80, I reckon that's a small price to pay considering the s**t they could of been in!, I noticed that 3 of the 4 Henleys were in bits almost so I told him and I've got that(small) job, also 4 x 100 amp main switch DB's on one phase , storage heaters on another and 60amp switched fuse on another, IMO although it's not a safety issue I think that needs balancing!, he said I can do that aldo
Reply to Call out charges - whats yours? in the UK Electrical Forum area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
