H
Hawk
Had a callout there to a shop. Outside lights tripping the main rcd. One of the son lamps was causing it. Replaced it and seems fine now. Done an ir test between live and neutral to earth and got a reading of >999. Bad set up cause if one circuit has a fault it takes out the whole shop not good when customers are in.
I have recommended putting rcbo's in. What are your thoughts? I have a system in place that notifies the customer of power cuts. He got a message at 4am this morning to notify him of a power cut. The system is good as there is freezers and fridges in the shop. However this doesn't solve the problem of the whole shop tripping!
