Came across some cable I haven't seen before | on ElectriciansForums
Discuss Came across some cable I haven't seen before in the UK Electrical Forum area at ElectriciansForums.net
mattg4321
V.Nearly Esteemed
South East UK
I came across some cable today I haven't seen before.
It has some sort of tough, inflexible pvc type sheathing (definitely not rubber). It's quite a light silvery grey and more oval shaped than modern flat T&E.
Rubber insulation.
No CPC.
Probably tinned copper conductors, but maybe even aluminium?
A picture paints a thousand words so here we go. Perhaps this is common in other parts of the country, but it's new to me.
  • [ElectriciansForums.net] Came across some cable I haven't seen before
I've seen lead sheathed many many times Tel. It's not. It's not rubber either. Some sort of PVC type material I'd say. Less flexible and tougher than modern stuff though. You certainly can't rip down it with a conductor like some do today.
It's lighting cable shown above. Everything else has previously been rewired. I also found some 3 core the same as the twin. Red, White and Blue. No CPC.
I've came across old pvc/pvc from 60s which has no earth in it and separate bare earth ran along side it, however the red and black sheath in that cable looks more like rubber from the picture
We don't just collect cable! :)
Rubber-insulated, plastic sheathed was a recognised construction but I don't know much about it, I will have to look it up. Natural rubber in good condition has extremely high insulation resistance, while early PVC was often considered an inferior substitute used only because rubber was scarce and expensive due to the war. So I think the idea here is to combine the benefit of rubber insulation with the economy and toughness of the polymer sheath.
I would be very keen to get hold of some lengths of this and would convert them into beers...
I'll put some aside tomorrow. I should be able to get hold of a good 4/5m length of 2core in good condition and possibly 2/3m of 3core in not such good condition (part of this has been painted at some point.
Reply to Came across some cable I haven't seen before in the UK Electrical Forum area at ElectriciansForums.net
