Camping bargain from China-RCD Electric Hookup ? | on ElectriciansForums
Discuss Camping bargain from China-RCD Electric Hookup ? in the UK Electrical Forum area at ElectriciansForums.net
west midlands -- UK
Just picked up 3 socket "mobile" Mains kit.
hi gear , with 16A isolator and 30 mA RCCB by Hgg .
It had the traditional at least 1 screw loose on Outgoing Neutral ferrule.
( finger tight )
Incoming cable is a bit frugal at 1.5mm sq( and GREEN ) .
Is anyone aware of other problem areas .
( It will be used for intermittent - light loads- a few days a year ) Camping .
--- Or I would have spent more --!
Blue plug 16A-6h -Moulded - No screws .
Is anyone aware of any reliability isues - if treated kindly . (un-wound!)
(Documentation supplied -advises -No unattended operation , get out clause )
( Splash proof but doesn't like rain . )
I would test the RCD to ensure it is correctly and safely operational before use.
Overall the unit sounds like it could be used reasonably indoors for a maximum of a 16A load.
No idea about the manufacturers but if the units are CE marked and state they comply with the appropriate British standards then you ought to be OK.
However the price does tend to err toward the low end of the market.
Reply to Camping bargain from China-RCD Electric Hookup ? in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
