Discharged
As per the title, really. When I say socket, I don't mean on a ring, I mean on the end of a flying lead.
I can't see why not so long as it's mechanically secure.
I quite often will use 2.5mm flex to wire to a flying socket (from an FSU) as part of kitchen installs - looks a little odd hanging out the bottom of the plaster but once the appliance is plugged into it you get 100% flexibility around pipes, cabinets etc. and don't have to worry pulling fitted applicances in and out.
I have seen one wired in a way that the casing of the socket was not fully closed up - around the cable entry. I know you can get a super mega (for want of a better word) MK socket, that can take the large cable, but not sure about the socket.
...furthermore...
If I have a 2.5mm cable as an extension lead - with a 13A socket on one end and a trailing socket at the other, can I plug that into another extension lead that is made up of 1.5mm cable?
What would happen to the capacity to carry higher loads, for example a 3kw heater?
I do this all the time.
If the 1.5 cable is sufficient to take the load, then there is not an issue.
My way of looking at problems is try to work out why you would not be able to do something.
You are asking if it would be a problem to use higher quality cable than required, no issues by me.
Was I making a mistake in assuming that 1.5mm cable could not be used with a 3kw heater? I know many of my questions might seem basic, but I don't mind admitting that I lack some basic understanding. Thanks for patience.
Just seen a job like this. 4.1kW industrial toaster. 20A breaker at the CU then 4mm armoured to a DP switch, then onto a flex outlet plate with 2.5mm H07 flex to the toaster.
p.s. Ref the CSA, how do I write the "2" for "squared" after the 4mm above? Been bugging me!
So you're saying that there is nothing remarkable or undesirable about this kind of arrangement where differing cabling is used, regardless (almost?) of the end appliance?
What you have to remember is that anything that involves a plug/socket arrangement also involves a 13A fuse. So as long as the cable, in any combination, is capable of carrying 13A, then you're fine.
The purists will now point out things like lengths of runs, voltage drops and how hot the thing might run to. Also, it's not a good idea to knowingly run the maximum current down the minimum cable just for the sake of laziness. Remember too that cable wound around a drum (as in a drum extension reel) needs to be fully unwound otherwise it WILL get very hot very quickly due to you having made an electromagnet out of it.
I have a thermostatic controller here that has a 40A relay in it - because the existing relay in the controller itself is 10A. So if this controller is connected to something drawing up to 40A, does that mean that the 13A fuse in the plug is going to blow?
If you connect a 40amp load to a 13amp fuse .................yes
You do know what these 40amp and 10amp ratings refer to ..............??
They are loads that can be applied to that piece of equipment, not what have to be applied, similar to the 100 amp switch in a CU, that is it's rated operating characteristics before failure.
This is all becoming much clearer to me so, so many thanks for the info. One thermostatic controller I know of has a 10A relay and the other a 16A relay... it now strikes me that the only reason the 40A relay is being used in the former is to boost its utility. In the latter, the 16A, it surely is not needed for a 3kw fire?
The way I come to this conclusion is by 3000w/240v= 12.5A - well within the 16A's capacity. Is this correct reasoning/maths?
What concerns me is that there is a controller out there with a 40A relay added, using 2.5mm cable, but with a 13A plug. How can that make sense? Should the advice be to not exceed 13A - not least because of the size of the plug's fuse?
How can you exceed a 13amp protection for a BS 1363 plug? You can;t 13amp is the maximum size fuse for that appliance.
The relay is rated 40amp as it is a generic piece of equipment. That is it's optimum rating before failure.
no............................... how much do you think a component company will charge if they have to make bespoke components? Your 16 amp only relay will cost 10's of pound instead of a generic 40amp one that will do anything upto 40 amps and cost a tenner.
They will make 2 or 3 relays of differing sizes and use them accordingly. They most like make the 10amp for smaller loads as the resources will be smaller and it is more cost effective. anything over 10 amps upto 40amp another type.
So the the 40A is just there for convenience? Why would the unit be carrying 2.5mm cabling? Is that really necessary in the instance when you can't exceed 13A anyway?
Not sure what this unit is, but any unit that is designed to have a BS 1363 plug on it, should not/will not have 2.5mm flex feeding it.
Unless the appliance is designed to be hard wired into a a suitable connection unit or it's been DIY'ed
Malcolm, I think you've really hit the nail on the head. I don't think the one I bought was DIY - it's far more likely that it was designed to be hard-wired in somewhere; why otherwise put that big relay in? I understand what you're saying about the component manufacturer, however.
Many thanks, this has been a real help.
Can 2.5mm flex ever be wired to a socket?
Australia
Discharged,
Discharged,
