Can an electrician move my BT Openreach socket for Infinity / telephone? | on ElectriciansForums
Discuss Can an electrician move my BT Openreach socket for Infinity / telephone? in the UK Electrical Forum area at ElectriciansForums.net
J
jonwade
I just spent 40 minutes on BT custhelp chat trying to get a simple answer and the person could not help me!
All I want to know is, can I get an electrician to move a BT wall socket (not master) from one room to another (new office in loft conversion, directly above old office where BT installed the open reach).
Pic of socket.
[ElectriciansForums.net] Can an electrician move my BT Openreach socket for Infinity / telephone?
The BT Cust help did say it would cost £205, which seems a lot to run a couple of cables up one floor. But maybe it is more complicated than that?
He also said that I could get an electrician to do it (although that conflicts with what I read on another forum, that the socket belongs to Openreach and they need to move it). When I asked about what cables to use, he said "normal ones" (took 40 minutes to get that far).
If this is a job a local (Chelmsford, Essex) electrician can do, approx what would be the charge?
I have asked the builder to ensure that there is a clear run down the back of the plasterboard from new office to current one, so hopefully it will be a straightforward job.
Thanks!
yes a normal electrician can do it.
as long as you have a live phone line they can move it.
i dont know how long it would take without looking but i would have thought half that would be more reasonably but it could be less it depends who does it
Would it be possible to add another socket to the OP's attic and just connect to the one in the pic. Might be less work or easier.
As said that is an NTE5, which should not be moved other than BT, why don't you leave that insitu, and get the Electrician to run an extension off that, obviously off the front plate.?
Reply to Can an electrician move my BT Openreach socket for Infinity / telephone? in the UK Electrical Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
