can any electrician install landlords electric meters | on ElectriciansForums
Discuss can any electrician install landlords electric meters in the UK Electrical Forum area at ElectriciansForums.net
sparky-s-w
hi a newbie here, i have been asked to quote to install landlords electric meters in my local area, but i have no experience in this. I'm guessing its the coin opperated type, and i dont suppose they are dificult to install, but i'm unsure as to weather i can just go ahead and install, or would need to inform energe suppliers, building control, etc. i'm qualified and registered to Elecsa.
Just re-read the question. This work may be beyond you if you are what we affectionately call a Electrical Trainee, are you a time-served spark? If yes, then it should be a straightforward job.....if not then don't bite off more than you can chew!
Reply to can any electrician install landlords electric meters in the UK Electrical Forum area at ElectriciansForums.net
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
