Can anybody identify what bulb i need for this fitting? | on ElectriciansForums
Discuss Can anybody identify what bulb i need for this fitting? in the Lighting Forum area at ElectriciansForums.net
Leehynes
Manchester England
Sorry if this isn't what this forums for but I'm at a loss and any help would be greatly appreciated, can anybody identify what bulb i need for this fitting?
It's an outdoor light if that's any help,
  • [ElectriciansForums.net] Can anybody identify what bulb i need for this fitting?
alternative to amazon,
? I've encountered a problem.
The bulb fits and attempts to light up but doesn't quite fully and flickers, is it worth trying to rescue the outdoor fixture which I've put the bulb in to, or is there a part I could get for it?
I've seen a bulb in my quest that was 'ballast bypass' with the same fitting... would this help?
Sounds like the gear (ballast) faulty.
Either replace that or retrofit an LED equivalent.
Or just change the fitting
Reply to Can anybody identify what bulb i need for this fitting? in the Lighting Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Just to say that the description of that safety bulb-holder does confirm if you take the bulb out, the pins are not live, even if the switch is...
