Can anybody recommend a good cable locator? | on ElectriciansForums
Discuss Can anybody recommend a good cable locator? in the UK Electrical Forum area at ElectriciansForums.net
P
phawk
Morning people,
Went to test an install yesterday after the builders had been in, and found they had gone through 3 of my cables!
'It's ok though, we just switched the RCD back on and it held in!'
Erm no mate, I'll have to dig those cables back out of the wall and crimp them'
'Nah it'll be ok'
'No it. ..kin won't!'.
Maybe wouldn't be so bad, but they did half my chasing for me so they knew exactly where the cables were run. Basically what I'm after is a decent cable detector (for live and dead cables) to reduce the risk of this happening again.
And before you ask about the 50mm chasing depth (of course I went 50 mm ;), they were using 75mm screws to install the kitchen cupboards anyway!
Thanks.
[ElectriciansForums.net] Can anybody recommend a good cable locator?
..........................It's ok I'll get my coat
You are right. A Cat would not actually work in that situation. You want one of the hand held wall scanners. the bosch is excellent. It has electromagnetics and radar so you can pick up both metallic and non metallic services.
Good luck.
Reply to Can anybody recommend a good cable locator? in the UK Electrical Forum area at ElectriciansForums.net
