Can anybody tell me what regulation they are breaking. ? | on ElectriciansForums
Discuss Can anybody tell me what regulation they are breaking. ? in the UK Electrical Forum area at ElectriciansForums.net
R
rockman
Can you tell me if i have a supply cable coming in, going to a suppliers fuse and from here we are using a double insulated 10mm cable, and we go straight to a fused spur with no other device what requlation are we breaking apart from 433.1.1
No there is no meter.
Is your cutout in a tall concrete or steel pillar with a lamp on top of it?...... this is probably a street light and is the property of the highways control agency only and because gypo's spend half their life on the roads they class them as their property to use at their convenience.
I did once, but only at college, where they insist that you double over your 1.5mm lighting singles, which then end up too fat to fit in the three-plate ceiling rose! My solution? Wait 'til the lecturer isn't looking.... oh look, they fit now!
Reply to Can anybody tell me what regulation they are breaking. ? in the UK Electrical Forum area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
