Hello all, can anyone clarify what this requires on a dno supply that needs to be upgraded. In regards to the earthing system, the application has a tick box which I'm slightly confused about on what it required, it's the part on steel framed building and why this is doneScreenshot_20210215-181744.jpg
I believe they are asking if the building will have a single DNO supply or multiple within the same building. If multiple supplies they are likely to consider an alternative means of earthing such as SNE (Separate Neutral Earth).
Birmingham
Business Name
Electrical solutions
Can anyone help.earthing system
Talk Electrician Forum
Thread Tags
Zahid Nawab,
westward10,
