Can anyone identify this part? | on ElectriciansForums
Discuss Can anyone identify this part? in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi,
I'm trying to fix an old battery pack that won't charge and I'm pretty sure this part is the culprit (when testing with a multimeter this part is breaking the circuit). I'm guessing it's a resistor? Could anyone please direct me to a replacement of the correct type? The second picture is what is written on the side - "10 A" followed by a letter "F" sitting within those two lines. Any help would be appreciated.
[ElectriciansForums.net] Can anyone identify this part?
I would be looking for another issue regarding the charger, check the batteries etc, this is a fuse and will act in a fault condition, the fact it has gone means it is likely it did what it supposed to do because a fault occurred.
When I delve into this stuff which really isn't my field I tend to solder a few tails and fit a loose fuse holder on temp' where I can quickly replace the quick blow fuses assuming I haven't located the fault prior.
He'll have done it by now, it was January.
Reply to Can anyone identify this part? in the UK Electrical Forum area at ElectriciansForums.net
