Can I add a switched outlet to an SAC | on ElectriciansForums
Discuss Can I add a switched outlet to an SAC in the DIY Electrical Advice area at ElectriciansForums.net
wraiththe
Charlotte, NC USA
I would like to know how to wire in a switch and outlet in my cabinet. Should I pigtail it after the GFCI? I would like to add a switch as well. Here is the wall, If I can utilize the outlet and add a switch here, wall access will be doable.
[ElectriciansForums.net] Can I add a switched outlet to an SAC
. [ElectriciansForums.net] Can I add a switched outlet to an SAC
My original intent was to add a switched feed to a junction box under my cabinet for LED lights to plug into (more like direct wiring because this was their wires and not a normal plug in. I was told that is not allowed (direct wiring of lights into a kitchen SAC.) so my next idea is to wire in a switched outlet to be placed in the cabinet
Reply to Can I add a switched outlet to an SAC in the DIY Electrical Advice area at ElectriciansForums.net
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
