Discuss Can I charge my caravan battery from my car alternator with a DC to DC while idling? in the Auto Electrician Forum area at ElectriciansForums.net
A modern car will charge at idle.Can I charge my caravan battery from my car alternator with a DC to DC while idling?
Even at idle the engine is turning at about 800 revolutions a minute.
Most are ecu controlled and will adjust idle to compensate for alternator load on the engine.
If it didn’t charge at idle you wouldn’t be able to leave it very long idling with the lights on etc.
Why would this require a DC-DC charger? Simple wire should suffice, and yes, it should charge while the car engine is idling.
That's exactly how I do it. I've wavered over the years whether a switch + relay/ ignition live source + relay / or if really pushing the boat out, a voltage sensing relay is best.Why would this require a DC-DC charger? Simple wire should suffice, and yes, it should charge while the car engine is idling.
The battery in my caravan is charged by the car alternator with nothing between them other than wire and N/O relay that closes as soon as the engine is started.
Aha, it sounds as though modern leisure batteries are lithium?! I can see that adds a new factor. I've never purchased a leisure battery in my life, as I've invariably got a serviceable spare car battery kicking about.Modern lithium batteries do not present a load to the alternator in the same way that a lead acid battery does and so a DC-DC charger can be installed to aid in charging.
Lithium batteries have found their way into caravans now? Think I'll stick with a good old deep discharge lead acid.
From my experience with lifepo4 cells on a boat... the 'standard' way to charge them is via a DC-DC converter off the Lead Acid engine start battery (or a dedicated 'intermediate' Lead Acid battery). This is done because the super low internal resisitance of LifePo4 cells creates a huge load on the alternator, it gets hot, then the dreaded smoke appears. So it's more a matter of too much load, rather than not enough.Modern lithium batteries do not present a load to the alternator in the same way that a lead acid battery does and so a DC-DC charger can be installed to aid in charging.
Almost all cars after 2013 will have smart charging and won't allow too much current.From my experience with lifepo4 cells on a boat... the 'standard' way to charge them is via a DC-DC converter off the Lead Acid engine start battery (or a dedicated 'intermediate' Lead Acid battery). This is done because the super low internal resisitance of LifePo4 cells creates a huge load on the alternator, it gets hot, then the dreaded smoke appears. So it's more a matter of too much load, rather than not enough.
Having said that, it does depend on what regulator you have on the alternator, whether integral or external.
Almost all lithium batteries will have battery management built in, some will also have heater, Bluetooth etc.Also... the OP should make sure they have some sort of BMS for safety. (Lithium cells have a different charging regime to LA)
It's only an option, I would have thought most people wouldn't want to pay the £300 - £1000 for a battery.Aha, it sounds as though modern leisure batteries are lithium?!
Reply to Can I charge my caravan battery from my car alternator with a DC to DC while idling? in the Auto Electrician Forum area at ElectriciansForums.net
