can i drop cables down 100mm internal metal plasterboard walls | on ElectriciansForums
Discuss can i drop cables down 100mm internal metal plasterboard walls in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stumas
can i drop cables down 100mm internal metal studded plasterboard walls as someone says i cant becouse the gap cuold be less than 50mm each side of cable, if not what should i do if i cant use rcd on the curcuit.
think you'll find that irrespective of depth, an RCD is required for cables in metal studding. 522.6.8
Reply to can i drop cables down 100mm internal metal plasterboard walls in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes, I realised the best thing would be to just fit a floodlight (LAP Weyburn Outdoor LED Floodlight Black 20W 2000lm - Screwfix -...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
