If they have never been used, I would seek advice from the forum I mentioned before applying power. One of the leading causes of damage to vintage electronics is applying power after a long slumber, when certain parts that fail through lack of use (e.g. electrolytic capacitors) cause knock-on damage if they are not checked and/or replaced first. Equipment of this age is on the cusp of this problem and whilst I don't know this particular model, from my experience of restoring vintage electronics I would personally be surprised if any NOS EIAJ deck worked straight out of the box. Helical-scan VTRs are inherently complex machines and cannot tolerate badly out-of-spec mechanics or electronics. Grease goes stiff, belts stretch, electrolytic capacitors go leaky, contacts go high-resistance, even if they are carefully stored. Someone who knows the model will be able to advise where the pitfalls are.
Having said they are available, I am struggling to find the off-the-shelf transformer model I was thinking of, and suspect they have been discontinued. I tend to make this sort of thing as I need it, or adjust the equipment as required, so haven't actually bought a ready-made one in a shop for a long time. A 110-115-230-240 autotransformer can be used 'upside down' with the common neutral at the 240 end and the 115 tap giving 125, although it would need derating as that end of the winding will be of lower current rating than the 110 end. Or a 230-10V stepdown can be placed in series with a 230-115, etc, but I'm not sure what your experience is with electrics so not sure if you prefer to get a ready-made unit?
In any case, the 127V units might be fine on 115 (particularly a 'high 115' such as from a transformer with the primary run at the top end of its tap range) and as I mentioned the 117V tap might be available internally with ten minutes work. In which case you might be able to use something like this:
http://uk.rs-online.com/web/p/autotransformers/0504199/
BTW how are you off for 1/2" tape?
