Discuss can i get a rcbo/rcd breaker for this old wylex board ? in the UK Electrical Forum area at ElectriciansForums.net
I hate those boards, who allowed the design of plug in breakers that the cover does not fit afterwards, they look terrible and should be replaced PDQ. I did a couple after getting a deal at B&Q, they had new wylex 17th boards on offer at £70 inc full set of breakers, i would try and convince the client to spend just a little more and get full house benefit of RCD. There are always deals around would price both up -
Why would you need a henley block?
Nothing wrong with these boards as such!! Replacement covers have been available from the very outset of the availability of the plug-in MCB's and are still available today.... I'm not saying they meet present day requirements, and probably need changing out now in a domestic setting, but these SAME CU's have been around probably for longer than you have, and still available today!! lol!! How many of these modern CU's will ever be able to match that sort of record?? Couldn't of been that much wrong with them... :wink_smile:
Or you could take the cable for the lighting circuit out of the CU and into a FCU RCD, then a new cable from the FCU RCD into the existing breaker.
Well i never, you know i have never seen a cover that fits once the re-wireables have been changed to MCBs, nearly all the DBs run without a cover or best i have seen is one where someone carefully cut out the old cover so it would fit. In the middle of a EICR which has two of these, if they are available then both the OP and i can get some, no idea where from though, i can just imagine the conversation i would have with wholesaler.
Reply to can i get a rcbo/rcd breaker for this old wylex board ? in the UK Electrical Forum area at ElectriciansForums.net
